too much oil now sluggish peformance!
Old 06-01-2008, 07:09 PM
macbeth18288's Avatar
Default RE: too much oil now sluggish peformance!
SO I guess the question is: how much did you over fill it by?
Old 06-01-2008, 07:11 PM
Yeah, a key piece of information missing here is the approximate volume of the oil over fill.
Old 06-01-2008, 07:14 PM
ej6buddy's Avatar
ORIGINAL: RonJ
BINGO! we have a winner
Old 06-01-2008, 07:38 PM
Nonetheless, until we know how much excess oil was added, it is safest to err on the side of caution and recommend that the excess oil be drained as soon as possible.
Old 06-02-2008, 07:04 AM
mundy5's Avatar
or rather than draining the excess oil, i'd recommend that all the oil be drained and refilled with 3.7 qts or so since the filter will not be changed.
of course, i'd recommend that you start with 3 qts and then add 1 pint more at a time to double check that the level is within the max to min range.
Old 06-02-2008, 08:06 AM
if you just replaced the oil..... why would he need to use new oil.... just drain it and put it right back in... as long as you use a clean pucket or oil pan then jut refill it and THIS TIME... dont put it all in.[8D] do little by little till you have it pretty close...
Old 06-02-2008, 08:11 AM
mundy5's Avatar
I'm sorry I was not crystal clear, but I did not mention any new oil in my post. I was thinking along the same lines of refilling it with the just drained oil.
Old 06-02-2008, 08:29 AM
07blksi's Avatar
I would definitely drain some out to make sure you are at the correct level. If your oil is frothing like a rabid dog its definitely overfilled.
As other people mentioned too much is the same as too little. Why chance it?
Draining oil is easy, if you can open up a soda bottle while lying on your back you can drain your oil.
Spend $50 on a small craftsman metric socket set and you will be golden for almost all repairs on your car. I swear my old honda only consisted of 10 and 12mm bolts (the occasional 14mm) and that god-forsaken bottom pully bolt (Blah, hated that thing, it hated me too...mutual feelings I guess)
Puchki
08-11-2011 08:43 AM
slideking
11-20-2010 05:10 PM
oilltd
06-10-2008 04:06 PM
timmytim
19
12-11-2007 09:42 PM
Quick Reply: too much oil now sluggish peformance!
