Tire.s cupping
Tire.s cupping
Hi all, the rear tires on my 2007 LX 4 dr. always end up developing a cupping surface and after rotating they all eventually have that cupping. This makes for noisy ruined tires. I had a dealer 4 wheel alignment after the OE tires wore out but the replacement tires developed the problem as well. So now my question is is this common with this generation Civic? Can this be fixed?
The cups
The alignment I mentioned was done at the dealer which explains why it didn't help. Yesterday I visited a tire/auto repair shop and asked them about my tire cupping problem. What they said was the cupping is due to the "camber" setting which has the rear tires tilted in at the top. To correct that they would install adjustable after market "control arms" so the camber can be set properly and avoid premature tire wear. They said this would permanently correct the problem without any ill affect to the handling or performance of the car.
Has anyone hear of this and will that fix it?
driveitlikeyoustoleit
10-25-2013 05:54 PM
jrichards016
05-01-2011 03:38 AM
kjsayers
06-10-2010 10:06 AM
