Timing belt questions????
I'm a firm believer in buying genuine Honda parts. Auto manufacturers, and any large corporation actually, have engineers that spend copious amounts of time/effort qualifying parts suppliers to ensure that nothing substandard is put into their marque that could tarnish the name. That said, even Japanese suppliers can have problems, and even though I am angry with Honda over a poor headgasket design, which I ultimately had to resolve myself, I still purchase genuine Honda OEM parts. My time is worth too much to spend it replacing 'lifetime warranty' sub-assemblies from the Auto Parts stores, repeatedly, and before they should have worn out. Couple that with being potentially stranded, or, in your case paying shop rates to have the parts removed/installed, it just seems to make sense to use the best available.
Majestic Honda has an online parts store from which they sell genuine Honda parts at, or very near, wholesale prices. A quick Google search will get you there. The shipping is reasonable and the service is quick.
As has been already said, I find standard replacements during a timing belt change to be:
Timing belt
Tensioner/idler pulley assy
Cam seal(s)
Cranks seal
Water pump
In addition, if your valve cover must be displaced to get the upper timing chain cover off (I don't know your particular engine) I would replace that gasket as well. They are not that expensive
Also, just as an added maintenance/visual verification, I like to keep my engine compartment clean and free of accumulated dirt/oil that can hide potential small problems, i.e., small oil leaks, white deposits from a pinhole in radiator/hose, brake fluid at the master/clutch, etc. I check under my hood at every fill up for a quick look. (What else to do while waiting for the pump?). Anyway, cleaning up your engine compartment before submitting it to your mechanic is not only respectful, but also advantageous for him/her to spot check components and seals while making repairs. Just a thought.
Hope this helps, offered as only suggestions.
Ed Fisher
Dallas, Tx
Timing belt
Cam seal(s)
Cranks seal
Water pump
Ed Fisher
Dallas, Tx
unlikely.
Thanks.
Kyle700
09-18-2014 08:44 PM
pippo
01-26-2010 03:40 PM
sd713
12-31-2008 09:30 AM
