Timing belt question
Old 09-11-2006 | 10:09 AM
packman5280's Avatar
Default Timing belt question
So, obviously, I need the actual timing belt, but for some reason I thought there was another belt in there that needed changing at the same time, but I now I can't find where I saw that. Not the regular serp belt, but actually inside the timing cover. Any idea what i am talking about?
Old 09-11-2006 | 10:12 AM
finalimpact's Avatar
Default RE: Timing belt question
ummmm what engine are you working with? b/d series engines only have one belt behind the timing cover. now if your talking h/f then you would be thinking of the balance shaft belt which also has to be in time with the tming belt.
Old 09-11-2006 | 10:46 AM
sorry, 2000 Si so b16. That's the one I was thinking, balance shaft belt. Do I have to worry about that with the B16?
Old 09-11-2006 | 12:11 PM
nope........were lucky.......balance shafts are usually found on 2liter and larger disp engines.
Old 09-11-2006 | 12:14 PM
sweet, so timing belt, tensioner, and water pump should be all I need. Thanks!
Old 09-11-2006 | 01:18 PM
yes sir........have fun with the r&r. and if the tensioner doesnt come with a new spring, get yourself one.
Old 09-11-2006 | 01:24 PM
Thanks again. Not looking forward to it, but I did the headgasket, timing belt, wp, and radiator in my 86 crx Si and I have the mitchel CD, hopefully I don't break the tensioner bolt off in the block this time.
Old 09-11-2006 | 04:01 PM
fglaustin's Avatar
i didn't do the tensioner, but i guess some do.
that spring screwed me up though, and i had to go back in there and replace it.
Old 09-11-2006 | 06:45 PM
Pedar's Avatar
Hi I saw your question and I know from experience water pump/ tensioner / any gaskets / any worn bolts
I priced it out to have it done got a quote for 425.00 for everything.
For what it's worth.
Pedar
smackpower
01-13-2024 01:42 AM
Kyle700
09-18-2014 07:44 PM
pippo
01-26-2010 02:40 PM
Legend1011
04-22-2006 03:09 PM
molson
03-04-2006 07:14 PM
Quick Reply: Timing belt question
