Thermo Sensor Switch
hey everyone,
i have a 97 Civic 160i SOHC. Problem im having is that my Radiator Fan is not switching on! SO the car is overheating.
I have been to a Auto Electrician and he concluded that the above switch is faulty. He disconnected the switch and done something and so the Fan switched on.
But when all is connected in its proper entiety then nothing happens, hence he says it is the Sensor Switch.
Any thoughts on that? Can i buy the part and fit it myself? Or does it take a Qualified Honda Mechanic to do it?
RE: Thermo Sensor Switch
Thanx KS200!!
Anybody here thats done it before and can tell me how to remove/install the switch?
The Auto Electrician said something about after the switch is removed something has to be bled before the new switch can be installed [&:]
Yep, that's all you need to do.
The mechanic was talking about bleeding off the system. The bleeder valve should be right near the switch, just warm up your car, give it a couple turns while running until all the air comes out.
KS200
KS200
SalPal
02-16-2014 03:55 AM
danomatic93
Routine Maintenance DIYs
01-15-2012 07:16 AM
Avast1983
06-14-2011 01:16 AM
civicwannabe
11-28-2010 05:52 AM
