Temperature Problem
Temperature Problem
I just bought a Civic 99 Ex. One problem I have is that the temperature needle goes all the way up in seconds, even though the engine is not hot. I suspect it to be a bad temperature sensor. Where is this sensor located? Thanks.
RE: Temperature Problem
OK. I found and replaced the temperature sensor and that did not fix it. The neddle is still going up all the way even when the engine is not cold. I guess it is a wiring problem. Any ideas how I can troubleshoot it? Maybe measuring a voltage or resistance en respect to ground? Thanks.
Ok. I found the problem. Appearently when the previous owner installed the carbon fiber trim on the cluster, he damaged the temp gauge. What I did was, I resoldered the connections and it got fixed. Thanks for all your help.
WINSTON WILLIAMS
12-01-2010 05:18 PM
civicshorty
10-21-2009 03:47 PM
