Temp/Speedo/Fuel Gauge not working
The temp, speedo, and fuel gauge are no longer working. I replaced one under the dash fuse that was burnt and inspected all other under the hood fuses. I replaced the dimmer switch. Finally, I replaced the gauge cluster with one from the wrecking yard. Now, here is the problem, when I replaced the gauge cluster with the used one from the wrecking yard, the fuel gauge suddenly began working, but not the temp and speedo gauges. Also, when I hit the blinker, the blinker lights in the dash do not turn on and when I turn on the headlights the panel does not light up. Thanks for any suggestions.
chloiebear21
12-24-2012 11:46 PM
Faramire
09-07-2009 02:27 PM
houstonewyork
08-11-2009 08:24 AM
siwel177
12
07-17-2009 06:47 AM
THE_CRIPPLER
10-05-2005 04:08 AM
