Temp. gauge going up and down
I have a 95 civic DX and the temperature gauge on the interior gauge cluster keeps on going up and down at a rapid pace. I know that the temperature of a car probably could not flucuate that quickly, so I'm wondering what it could be? The car only has 75k on it.
Any help would be appreciated, thanks.
RE: Temp. gauge going up and down
Sounds like my car! I have a '95 DX as well, and the head gasket started going last September, but I didn't do anything about it until May of this year (don't be stupid like me!). Get yourself into a reuputable shop and get a pressure test.
Total repair was about $625. A big chunk out of my wallet, but it's cheaper than a new engine down the line!
what do you mean by up and down at a rapid pace? If the needle is jumping around randomly it could be as simple as a grounding issue on the guage. If the needle is moving up and down in a smooth movement then yes it could be a head gasket, warped head or cracked head. get it checked out soon.
Mine was doing that about a month ago. These guys are great. Told me it was the head gasket and it was, my head was also warped .01". Get it machined, put a new head gasket on it, and your all fixed. Be sure to get it pressure checked also.
I have recently seen the same problem. The gauge goes up and then back down slowly, but never gets real hot. I also noticed a loss of power when this happens. There's no smoke, and the engine runs great for about 30 minutes,no sputter, no misses and great acceleration..then seems to get sluggish. I relaced a stuck thermostat about 2 weeks ago, and there wasn't any problems til just a few days ago. Someone told me that I need to bleed the cooling system that I have air in it,..and there's a bleed port next to the thermostat,..? The oil looks ok,..no smoke, and no leaks,..is this a possible fix....jim
