stumped for days, idling problem
Old 12-09-2007 | 12:42 PM
rcalimquim's Avatar
Default stumped for days, idling problem
ok, i replaced the iacv, adjusted the throttle screw,even the tps sensor position. the car is idling around 1700 rpms. also noticed when i pump the brakes a few times in neutral the rpms go up is that normal? my setup is 97'civic ex 5-speed(d16y8) w/edelbrock turbo kit. been working on dropping my idle for a few weeks and nothings working, and i got a skunk2 68mm throttle body on it. im stumped, need some new info.
Old 12-09-2007 | 02:13 PM
Default RE: stumped for days, idling problem
When the CEL is not ON and not indicating code P0505, then the 96-98 Civic service manual recommends troubleshooting of several different circuits (see picture).
[IMG]local://upfiles/25538/A933FEC668F54C51959A2F49CAA6C056.jpg[/IMG]
Old 12-09-2007 | 02:18 PM
vacum maybe off??
Old 12-10-2007 | 01:07 PM
cmfmets's Avatar
Have you replaced the PCV Valce lately? I had an idle problem where it wasn't idling right at all and sometimes it would not want to start. I swapped out the PCV Valve and my car is running like a champ now. Hope this helps.
Old 12-11-2007 | 05:45 PM
rcalimquim's Avatar
changed pcv valve already, still the same.
Old 12-11-2007 | 05:46 PM
rcalimquim's Avatar
the cel code im getting is po117 - engine coolant circuit low input
Old 12-11-2007 | 06:31 PM
This is crucial new information as the P0117 CEL code possibly indicates the cause of your high idle problem. In this regard, the ECU uses temperature signals sent by the ECT sensor to control the amount of fuel injected (picture #1). Picture #2 describes how to troubleshoot the ECT sensor if you have a scan tool with this function. Otherwise, you might just try replacing the sensor, which is located below the distributor (see picture #3 in my next post).
[IMG]local://upfiles/25538/D1836C9755F84BDF9BE59F1CFCEBA205.jpg[/IMG]
[IMG]local://upfiles/25538/E72DCA29759F4D4880B1B9A8DB5402B1.jpg[/IMG]
Old 12-11-2007 | 06:32 PM
Last picture...
[IMG]local://upfiles/25538/DCB115F5084D4131B866F0783A6B3AD3.jpg[/IMG]
classiccarsrule85
22
03-31-2008 05:14 AM
Pete
11-27-2005 09:57 AM
goldfinger
09-16-2005 02:28 PM
kerosene
09-05-2005 09:53 PM
forcefedcivic27
08-24-2005 06:52 PM
Quick Reply: stumped for days, idling problem
