still bad idle need some ideas? 96 ex
about a month ago light came on got it scaned came misfire in 2 of cyl. since then i replace coil after losing spark. i have changed cap,rotor,plugs,wires,fuel filter,icm. tested fuel pressure is good,ajusted valves it raised compresion in cly to around 180. the one cyl #2 is at 90 and when put cap of oil it raised to 120. i also last weekend took injectors out and cleaned them and thottle body was removed and cleaned was a little sticky when closed works good now. car runs real good driving my problem is at a stop. idle drops to 500 or lower rpm thats when light comes on. if i turn ac on idle kicks up so it makes me think iac is working. any info would be greatful and thanks in advance.
Loveoldhonda
12-28-2011 07:18 AM
PineappleMan
02-24-2010 03:38 PM
boburke
04-23-2008 11:38 AM
