Stiff Gas Pedal
Stiff Gas Pedal
Hello again!
Can someone tell me how to adjust the gas pedal stiffness? When I go to accelerate, it don't go in smooth. Instead, when I push on the gas, I have to apply more pressure to make it accelerate. When I do this, it forces me to push it too hard and it jumps in. Just really stiff. Any way to adjust?
Oh yeah, there are no kinks in the cable line either.
RE: Stiff Gas Pedal
If you have to press hard to get off of idle, then it "pops" open, that's usually because there's a bunch of black gunk in the throttle body and the edge of the throttle plate. They stick together at idle.
RE: Stiff Gas Pedal
ORIGINAL: Sigracer10
make sure there are no kinks in the throttle cable. you'll see it on top of the engine, you really cant miss it. just make sure its a smooth curve and not bent anywhere
