stalling problem
Old 05-13-2008 | 03:41 PM
me262dave's Avatar
Default RE: stalling problem
Mk, I left out some of the stuff I had checked.
Because I had pulled the injectors, and reused the o-rings, my first thought was that fuel was leaking under pressure.
So I pulled the plugs to both injectors, and did not get fuel when cranking. So the seals are working and the injectors are not open. I will check the map sensor, I also have access to acompany that overhauls ecu's, I will call a tech there and ask if the ECU'shave a history of fuel signal problems.
FadedShadow01
11-13-2007 09:30 PM
onday49
11-13-2007 04:27 PM
paul_l
08-23-2007 08:54 AM
hova82
01-05-2007 01:39 AM
CivicSI4
07-14-2004 12:17 AM
Quick Reply: stalling problem
