srs light
srs light
since i'm takin whole itnerior out i took the front seats out as well, and then when i put it back i did not connect the seat belt cable back and turned the engine on, srs light came on, i turned off the engine, took the - connector from the batter for around 12 hours but the light is still on. how do i get rid of the light?
RE: srs light
I have the same problem. I posted the other day but no replies yet. But I may have found a website with an answer.
http://www.geocities.com/myintegra96/srs.html
No guarantees, I have not had an opportunity to test it out yet. Actually, I'm in the process of buying a car with this same problem. Was told it came on after a bettery was changed.
Good Luck.
Just in case, try and keep away from the airbags when doing it.
Good Luck.
RE: srs light
heh, i dont think i would risk this, if you have a scanner you can reset it too, my friend used to have a scanner but it got stolen so i'm lookin around trying to find some1 who got it. i tried disconnecting the battery for more than 24 hours but it did not help. i might have to go to the mecanic adn pay him 30$ to reset it
RE: srs light
went to the car stereo/alarm shop and they had a special tool to reset it. i tried it myself first with my scanner and it didnt work. they said honda srs system requires only a honda computer to reset the light. but i think what he did was the procedure mentioned above, he connected cables somewhere, turned the ignition on, shortedned the wires, did it again few times and the quilty turned off the ignition. the light dissapeared, this procedure cost me 20$. despite that its the same procedure mentioned above i would rather pay 20$ then risk my airbags
RE: srs light
I tried this link on my 97 Civic, and it worked great. There is no way of setting off your airbags, you are simply completing the circuit with the jumper wire. It's very simple, but one other way of allowing the dealer to make money off you, the consumer.
fivebells
08-09-2014 06:10 PM
houstonwide
11-17-2005 09:57 PM
