speedometer stopped working
i was driving yesterdayy and everything was working normal. after 5 miles of driving my needle drops to zero and stops working. i stayed at me friends house for 45 mins and it works agian until 2 miles later. today i only traveled 1000 feet and it stopped working and it still isnt working now. any ideas?
have you checked your VSS?
Vehicle Speed Sensor. it should sit right on top of the tranny.
check if its dirty or something? becareful witht the little metal rod and spring thats in there.. dont loose it lol.
does the tripmeter or odomoeter still turn even when the needle is flat?
If CEL is on, check the CEL FIRST!!
If the CEL pertains to the speedo sensor, ding ding ding, it's probably just the sensor located ontop of the transmission.
If CEL is NOT on....
Problem: The speedo doesn't work but the odometer works.
Solution: Replace the cluster or just replace the speedo gauge
Problem: The speedo doesn't work AND the odometer doesn't work.
Solution 1*: Bad Sensor - Replace the speedo sensor in the transmission.
*CEL should be on
Solution 2: Bad Gauge - Replace cluster or just replace the speedo gauge
IF Neither solution above fixed it.
Solution 3: Check all wiring from the sensor to the gauge. Because the signal is disrupted somewhere.
*CEL should be on
Brian
16
12-25-2021 03:12 PM
poke4802
04-23-2006 01:31 AM
stick only
01-04-2006 09:05 PM
farkus
11-24-2005 08:46 PM
cfauvel
09-22-2005 01:23 PM
16, 1993, 2008, 45, civic, honda, odometer, quit, short, speedmeterit, speedometer, stopped, stops, stopworkhond, working
