speedometer quit
Old 10-25-2008 | 10:38 AM
bafpc1's Avatar
Default speedometer quit
also cruise control is it vss 96 civic
Old 10-25-2008 | 10:52 AM
How many miles does it have on it? With it being a 96, and if it is a higher mileage car, it is possible that the speedometer itself has gone out. But the VSS is also a possiblity.
Old 10-25-2008 | 11:06 AM
The fact that both the speedometer and cruise control have failed strongly points to a faulty Vehicle Speed Sensor (VSS) located on top of the transmission. I would also guess that the CEL is ON. Pull the CEL code as detailed at the link in my signature. It should confirm the VSS failure.
Old 10-25-2008 | 01:54 PM
dito.... the CEL light should be on if the cruise doesnt work... if it was just the cluster going bad your cruise would still work i know that for a fact
Old 10-26-2008 | 10:38 AM
bafpc1's Avatar
thank you vm
Old 10-26-2008 | 10:47 AM
bafpc1's Avatar
thanks again ron does it just drop in place?
Old 10-26-2008 | 10:56 AM
if ur talking about the VSS yes for the most part. a plug on top and one bolt holding it to the tranny. JUST BE SURE before you EVER try to do anything more than finger tighten that bolt that the sensor is all the way seated into the tranny case! i didnt and ended up snaping off the mounting flange. and since it only has one bolt holding it down youd destroy the sensor. i did it and had to buy another... it sucked!
Old 10-26-2008 | 05:06 PM
bafpc1's Avatar
thanks bass
tireking
01-25-2010 07:40 PM
choadtx
02-10-2009 12:40 PM
av3rag3am3rican
10-06-2007 08:33 PM
sincitycivic
02-21-2007 12:01 AM
mayder
11-14-2006 01:38 AM
Quick Reply: speedometer quit
