Speedometer help
Old 11-02-2006 | 01:23 PM
HARI.'s Avatar
Default RE: Speedometer help
ORIGINAL: 006r
Is it hard to change the gauge cluster??
nope, on the 96-00 civics, unscrew the 2 phillips, take off the cluster bezel, and unscrew the other 2 phillips holding the cluster.
  #22
Old 11-02-2006 | 01:49 PM
006r's Avatar
Thanks just found a FAQ about this.
  #23
Old 11-27-2006 | 09:28 AM
aquajon's Avatar
what would happen if you just left the connection off of the vss?
  #24
Old 02-19-2007 | 03:37 PM
stang233's Avatar
Hey I found this post, what else did the rest of you do to fix the problem. Please let me know ASAP. I am going to check the VSS but also did most of you need a new cluster. Also how do i adjust themilage on the new cluster
  #25
Old 02-19-2007 | 03:41 PM
stang233's Avatar
I have a 95' civic LX and it has an intermitent problem with the speedo. Sometimes it works, sometimes it doesnt. But the cruise still works when the speedo doesnt and I dont get any kind of engine codes. Judging from what was posted before, this leaves it as the cluster is the problem not the VSS??? Becuase the ECU and the TCU and the Cruise control all work so the only thing left is that the guage cluster is bad somehow. Can someone confirm this for me??
IS THIS TRUE??? This would eliminate the VSS being bad and i can just get a cluster.
  #26
Old 02-19-2007 | 08:33 PM
bensminger2003's Avatar
Save yourselves some headaches and just replace the cluster. Mine did the exact same and I replaced it and the speedo started working again. The only prob I have with mine now is that it always reads 5 mph too fast and it has the correct tires it calls for so I bought a new speed sensor for it....that should fix it I would hope.
But yeah...replace the cluster and you guys should be back in business!!
  #27
Old 02-20-2007 | 06:23 AM
Red Hot Rider's Avatar
I just swapped my cluster for an EX one, so that I could have the tach. I have the DX cluster with a speedo that has 88K on it. Just pay shipping and you can have the whole cluster. Speedo will fit any cluster 96-00.
  #28
Old 05-01-2008 | 04:33 AM
natas915's Avatar
Ok this is the second post I do about the same problem, My speedometer went out about a month ago and I read in this forum to check the speed sensor and I did and it looked like crap so I replaced it, then I replaced the cluster (Thank god for Ebay). and my speedo is still not working. What is left? Oh and I also checked the fuses and the guy I bought the car from had replaced the 15 amp fuse with a 30 amp fuse so I swicthed them out and disconnected the battery and removed the back-up fuse hoping to reset the ECU and the car in general. On a side note in case it helps solve my problem, the speedometer was the only thing not working, my odometer was fine.
  #29
Old 05-05-2008 | 04:05 AM
natas915's Avatar
ORIGINAL: natas915
Hello? Help Plaese?
1meanb18
07-15-2006 02:22 PM
stang233
06-06-2006 06:08 PM
lzyga05
05-29-2006 10:55 AM
civicfan87
02-09-2006 01:48 AM
AnakinKenobe
08-19-2004 06:44 AM
