speed sensor
Old 01-09-2008, 04:40 AM
danomatic93's Avatar
June 2010 ROTM
Default RE: speed sensor
good lord. She was looking for a code reader output. YOU DON'T HAVE ONE! All you have to do is test your speedo sensor, not pull a engine code. If you wanted to pull an engine code you'll have to do it manually, search how to do it if you want.
I am 85% sure that if you just suck it up, buy the sensor and replace it, your problems will go away.
Old 01-09-2008, 07:54 AM
galaxysbaby's Avatar
cool thanks for the reassurance!!!
Old 01-09-2008, 09:05 AM
The '95 uses OBD1 codes, which are read by jumping a test connector under the extreme right end of the dash then watching the check engine light blink. They don't have an OBD2 connector obviously. Nearly all cars '96 and newer can be read with an OBD2 connecter under the driver's side of the dash, which is what the somewhat trained person at Advance was looking for.
I think a bad speed sensor will set a code. But if you've confirmed the odometer quits along with the speedometer then it's almost certainly the sensor anyway.
Old 01-10-2008, 02:56 PM
wireyanker's Avatar
search for this one 96-00 speedometer problem suggestions it may help you i just did it
spauldingscivic
03-17-2008 07:12 PM
sway2003
02-22-2008 08:34 AM
batac_boy
02-07-2007 11:17 AM
roudan
01-06-2006 02:43 PM
Auto98EX
10-07-2005 10:54 PM
Quick Reply: speed sensor
