speed sensor
Old 12-27-2007, 02:04 PM
galaxysbaby's Avatar
Default speed sensor
i have a auto. 95 civic lx. my speedometer quit but it will bounce around and sometimes works. the odometer works if the speedometer works but i think it quits when the speedometer does. id like to check the sensor but i didnt get a manual or anything so could someone just tell me were to find it? and when i locate it what sould i look for?
Old 12-27-2007, 02:08 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: speed sensor
If the speedo and odometer don't work:
A. COMMON: It's the Speedo Sensor on the transmission
B. RARE: The gear inside the transmission is broken
C. RARE: The wiring has a short somewhere
If the speedo doesn't work and the odometer works"
A. COMMON: It's the gauge in the cluster
B. RARE: The cluster's wire paths are messed up
Old 12-27-2007, 02:15 PM
June 2010 ROTM
The speedo sensor is on top of the transmission.
Now, this is a manual transmission so it'll look a little different. Plus, the starter isn't there either.
The label on the trans would be facing the front of the car.
Old 12-27-2007, 07:29 PM
but the sensors in the same place on an automatic, right? thanks guys!!!!
Old 12-27-2007, 07:34 PM
oh yeah....how do i test it? once i get it out, how do i know its broke???
Old 12-27-2007, 09:34 PM
June 2010 ROTM
Well, heck, I don't know how to test it other than borrowing one from someone you know. Sorry
Old 12-27-2007, 09:46 PM
ORIGINAL: galaxysbaby
The pictures show how to troubleshoot (with a multimeter) and, if necessary, to replace the speed sensor.
Old 12-27-2007, 09:51 PM
June 2010 ROTM
Thanks RonJ! I knew there was an actual way of testing it. lol, I just know a bunch of Honda gunkies so I can check things the wrong way.
Old 12-28-2007, 03:42 AM
thank you thank you thank you!!!!!!
Old 01-09-2008, 03:05 AM
ok so i took the car to Advance to get the cel read and the chick squirmed all under the dash and came out saying the car didnt have a plug for the tester. any thoughts?
Quick Reply: speed sensor
