some electrical problems
since I have bought the car...the heat/ac control thing has never lit up. Figured the bulb was out. But the other day it turned on..but real dim..when I touched it it turned off and neva came on. Is it a loose wire? Can I remove the besel without removing everything else?
Another issue I have it the gauges (speedometer and gas etc) at time that light starts to fade out, but I noticed that when I touch the top portion of the dimmer light switch they come back on to regular brightness. Can this also come off to check the wiring behind it. Or is there something else I should look for that's causing these issues?
Gently pry the dimmer switch out of the dash. Then unplug the connector and install a jumper wire that connects the Red and Red/Black wires in the connector. If the dash lights no longer have the dimming problem, then the dimmer switch is bad.
Oblivionlord
07-18-2010 09:42 PM
fierychick
01-29-2009 11:23 AM
94VTECoupe
05-18-2007 06:49 AM
abe_frohman
09-17-2005 08:05 AM
