Mechanical Problems & Technical ChatIf you've got a problem you just can't figure out, a noise you can't diagnose, or a check engine light that won't go away, ask about it here!
I have a 97 civic with 150k The steering is starting to feel a little sloppy, would this most likely be the rack and pinion or could there be other causes?
Could be a number of things. Front hub bearings worn, tie-rod end loose, steering gear loose/worn, warn/loose intermediate shaft. Can't really think of anything else.
