slight whirring noise with clutch out, anyone know?
hey, i have a 97 civic 5M, and one of my more mechanically inclined friends told me that he noticed a small whirring noise when my clutch is out, a noise that goes away when i push the clutch in. it's really slight, and i can barely hear the difference, but he said that it'll get louder with time, and might be the clutch bearing??
has anyone else had this problem? since he wasn't sure exactly what it was, i want to get it diagnosed in case it turns into an expensive repair, so i can start saving for it.
"When you push the clutch in, the throw out (TO) bearing comes in contact with the pressure plate (PP) fingers and spins with the PP. When the clutch pedal is out, the disc is engaged so the input shaft is turning. If you have noise when the clutch pedal is out and it goes away when you push the clutch pedal in, your tranny input shaft bearing is shot. If you push the clutch pedal in and you get a bearing noise then it's your TO bearing."
which makes more sense, right, for the tranny input shaft bearing to be making the noise when the clutch in out than for the throw out bearing to be doing so.
anyone know how much a shop charges for changing the tranny input shaft bearing? i read that the parts are pretty cheap, not more than 50 prolly, but the labor is a bitch. just don't wanna get ripped off. i'll probably attempt it myself if i can find someone with all the tools.
Push the clutch lever toward the cylinder (pushing the cylinder piston in) some and then the throwout bearing won't be touching anything so it can't make noise. If the noise remains, it's the input shaft bearing(s) in the transmission. That is also very common. Make sure the transmission is full of the proper fluid.
To change transmission bearings you have to take the transmission out of the car and open it up. It's not a full rebuild so it only takes an hour or so inside the transmission. Unless the clutch has been replaced lately, most people would also put a new clutch set in while the transmission is out.
so i gotta go to a dealer to get the parts, right? do all dealerships sell parts for the same price or do i have to be careful about where i go to get them? i'm in san diego, anyone know of a dealer here?
sorry, new to doing repairs. is this the part number i need? 91002-PHR-003
slideking
04-16-2010 03:17 PM
MaximusFunk
04-02-2009 08:50 AM
addiction2bass
12-30-2007 10:32 AM
speechless33759
04-26-2006 08:50 PM
Squeek
05-22-2004 12:32 AM
1997, 97, bearing, civic, clutch, clutch noise, clutch whir, honda, makes, noise, pedal, small, tranny, transmission, whirring
