Shifter play
Old 06-11-2010 | 10:41 AM
Davex's Avatar
Default Shifter play
I have a 1999 civic cx with 66,000 klms and the shifter has alot of side to side play.Shifting from 1-2 does not line up........I have to hold it to the left.Some times it is difficult to find reverse.Had the bushing at the bottom of the shift lever replaced and the stabilizer bar bushing close to the transmission replaced.Problem still exists.Transmission shifts and sounds fine.Would the pin that connects the shift rod to the transmission input shift shaft be worn?
Old 06-11-2010 | 11:14 AM
civicexracer's Avatar
Try tightening up the shift lever bolt itself some more. In the diagram its number 21/24. That usually gets rid of any sloppiness. If you tighten it to much, then the shifter will become too tight and shifting will be hard.
Old 06-11-2010 | 11:58 AM
Davex's Avatar
I think that will only make it stiffer but not deal with the side to side play.
addiction2bass
03-28-2010 11:34 AM
Mr^Man
Transmission and Differential
10-19-2008 04:21 PM
addiction2bass
12-25-2007 10:46 AM
mitsuman57
02-26-2005 10:04 AM
NTX
02-25-2005 07:05 PM
Quick Reply: Shifter play
