Shake between 50 & 65???
I have a 95 LX and it has been great. But the other day I hit a driveway entrance maybe a bit faster than I should have, enough to get the airdam to hit...the next dayit has a steering wheel shake only between 50-65 mph. Its not related to engine RPM and above 65 it goes away as well. Any ideas? Tie rod ends? Ball joints? Let me know some ideas that I can check tonight.
RE: Shake between 50 & 65???
Whats your climate like? if it is cold and snowy then it could be ice buildup on the control arm, that will do it, just take a hose with hot water like at a wash place and spray off in behind the wheels
Have the wheel balanced. You might have damaged the wheel when you hit the curb. Things that spin are kinda wierd with the weight distribution, you might have runout on your wheel.
firblitz
01-28-2007 12:33 PM
bain0005
07-08-2005 02:23 AM
