Sever Sluggish,bogging and jumpy acceleration
Old 08-17-2009 | 08:38 AM
Young Blood's Avatar
Will do that today!Is there a way I can test the Igniter? Multimeter? I repair electronics on radars some familiar with multimeters.I did use a torch to get the old rotor off cause the medal part was rusted on bad but I blocked the wires and componets with sheet metal, maybe I heated it up too much... I will post status later when I get home, Im at work, working very hard! Or hardley working...haha
  #22
Old 08-17-2009 | 03:25 PM
OK..big problem, I put new igniter in and car would not start, turned overn and almost started but didnt. I double and triple checked connected wires. The when I used a 19mm to rotate the pully to turn the cam shaft so I could get to the rotor screw I noticed that the cam wasnt turning when i turned the pully anymore. So i slightley turned the cam the opposite way and the i felt it release and it started turning again when i turned the pully??? Is there something wrong with cam?? I measured correct voltages at all points on the igniter. I pulled distributor and now im on my way to get new one......OMG this is getting tiring
also i noticed a cracked wire on the igniter.
  #23
Old 08-17-2009 | 03:30 PM
You should be fine. Only turn the crank counterclockwise. Turning the other direction will loosen the timing belt. Just re-rotate in the correct direction and verify the mechanical timing.
Replacing the distributor is probably a good idea at this point.
  #24
Old 08-17-2009 | 03:34 PM
Ok, if im standing at front bumper, looking down at the pully am I pulling towards me to rotate or pushing away. I had a "self proclaimed" Honda tech tell me to push away to rotate.
  #25
Old 08-17-2009 | 03:37 PM
Standing on the left side of the car facing the driver's wheel, you only turn the crank pulley counterclockwise.
  #26
Old 08-17-2009 | 03:47 PM
so do you think that caused my timing belt to be off-and it be the root cause of all of this? because I have turned it in the wrong direction several times.
  #27
Old 08-17-2009 | 03:52 PM
Not necessarily. Just turn the crank 5 or so revolutions and then verify that the cam and crank are still perfectly synchronized at TDC1. If so, all should be good.
  #28
Old 08-17-2009 | 03:59 PM
should I do that before I put the new distributor on or wait until after I put it on-I already took it off.
  #29
Old 08-17-2009 | 04:00 PM
Before or after, whichever is most convenient.
  #30
Old 08-17-2009 | 04:10 PM
i read a note in the haynes manual that said do not move the cam shaft once the distributor is removed-just wanted to make sure.
Quick Reply: Sever Sluggish,bogging and jumpy acceleration
