scraping noise
scraping noise
95 civic lx manual
Just recently, I've noticed a scraping sound coming from (only listening inside the car) front right wheel area.
I replaced both front axels a couple years ago if I remember correctly, no problems since then.
It's almost like if your muffler were dragging on the ground maybe, but not very loud.
Here's the mystery...
it only makes the noise while accelerating or coasting, and when I apply the brakes, it stops. Eventually it stops after a few minutes and it doesn't always happen. I think it also may have come back a few times during a regular drive.
Only consistency is it happens unless I'm braking.
Think there's something scratching against the pad and when I apply pressure, it just squishes and shuts the noise up?
ok, well I finally got around to looking at them yesterday, well just the side that I thought was scraping.
The pad was pretty worn down. I set out to get a new pair, but then I realized I might need new rotors as well.
My manual didn't really give me much help with seeing how to check to see if they need replacing or not and google keeps giving me the pads.
I also saw a tube/hose about 1/4" in diameter just kinda chillin by where the brake line (I think) comes through. It wasn't connected to anything, but was leaking fluid. The fluid was clear and odorless and none of my reservoirs were low. It was pouring out, but it was dripping enough to cause a concern.
This just water from something? I only ran my car to get it into the garage, so I figured AC was out (plus AC wasn't on).
I can try to get a picture of it when I redo my pads.
Ok, then I take it they're fine. There was about 1/16" left on the pad (eyeballed), the minimum required.
The rotor just looks shiny where the pad runs, I'm just not sure what the metal on the rotor would look like.
HyundaiCivic
09-18-2008 01:41 AM
ChicagoCivic25
07-30-2008 06:41 AM
comapro
08-18-2006 03:26 PM
