Reverse gear issue
Reverse gear issue
I have 98 civic hx and im having issues when i put the car in reverse. When i press the clutch and try to put it in reverse, its very hard and kida cranks when im finally able to put it in gear. Let me know if anyone has any suggestions on what can be wrong or what i can do to fix it.
When the gears grind when you try to go to reverse with the car fully stopped, that is actually a clutch issue. Pushing the clutch in is not stopping the shaft of the transmission like it should. First thing to check is the clutch fluid level.
Define "cranks when i get it into gear". Reverse is a square cut gear and is normally more noisy when you use it. Mine is more like a waahhhh sound.
I've found that many times mine is difficult to engage as well, especially if my foot is on the brake. Most always if i release the brake, it goes in fine because the wheels are able to move just a little so the squares line up.
If you're hearing gear griding and arent rushing the shift, then it may be a bad master or slave cylinder on your clutch line. I usually have to give it a second or two after pressing the clutch in to let the input shaft slow down, otherwise I'll hear a grind....
mudhenFUF
01-16-2023 08:43 PM
EnT3RiX
01-22-2007 04:35 PM
HaZe89
06-25-2006 01:05 PM
