Replacing bearing on A/C compressor.
98 1.6L DX
How hard is this to do?
I have unbolted the power steering pump and moved it out of the way.
I pulled off the A/C compressor belt tensioner. Popped the seal off that bearing and lubed it.
When I spin the compressor pulley by hand; it spins easy but is noisey. Sounds like when you clean all the grease out of a bearing and spin it.
Is there any way to lube this bearing?
I don't think so; so therefore I figure I have to replace the clutch / bearing / pulley assembly. The part is $337 Cdn. at the Honda dealer.
I figure I can unbolt the compressor, disconnect the wiring and lift it up where I can work on it without disconnecting the hoses.
Do I need a special type of puller to get the assembly off the end of the compressor?
Should I just leave things alone? So what if the bearing is a little noisey, just turn up the radio; or is it going to sieze up, break the belt, wreak the compressor; maybe a chunk of belt will damage the power stearing pump.
Or if I do work on it am I going to create a leak in the A/C hoses with all the movement?
You understand what's going through head. I need some opinions from people who have done this before.
RE: Replacing bearing on A/C compressor.
ORIGINAL: potsie
98 1.6L DX
98 1.6L DX
Good Luck
YUes replacing the bearing is not an easy job. But if you replace it not it is very good. B/c if the bearing stop turning the rotor locks up and the belt will break and tear anything in its path. all wires and even cut through fuel lines electricl wiring sensor wiring you name it anything in its way is history so yes do it now and quickly. and do it right Jeez
sparkhard
12
07-26-2011 09:36 AM
bustedknuckles
02-18-2011 12:27 PM
mike2009
08-02-2009 04:17 PM
