Replacing axle shafts - '98 EX
Hi all,
The wife's '98 EX has torn a CV boot, and I didn't catch it until now. I figure it's easier at this point to replace the axle shafts with rebuilt units.
I've changed shafts on other cars, but not on a Honda.
Anything I should know before I tackle this project? Any tips that the experts can give me to make it as easy as possible?
Also, do I have to get past that factory-deformed nut at the end of the axle shaft?
Thanks, guys!
Thanks, guys!
leave wheel on, take center cap(if you have them) of hub cap off, remove that big center nut, then jack car up remove wheel, unbolt bottom bolt on shock fork, then
then pry axle out from trans and install new axle, MAKE SURE NEW AXLE GOES ALL THE WAY IN TRANS(NO GAP)
Use a hammer and punch to punch the deformed part of the nut back out if you want to, though with enough force it will just unscrew anyway. Like 94 said, loosen the axle nut first before taking anything else apart. If you don't have an impact wrench do it with the car on the ground reaching through the center of the wheel like 94 said.
No you don't have to drain the fluid. A little MIGHT trickle out but that's about it.
Make sure you pull out the retaining clip when the axle comes out, you don't want that left in there. And yes, make sure when installing the new one that tenretaining clip has snapped in place and the axle is all the way in.
em1lover576
01-18-2012 01:16 PM
chuzie
07-30-2010 01:28 PM
