Replaced stock stereo and turn signals dont work
Ok so I am new to this but please help me out so yesterday boyfriend put in an aftermarket stereo, took out pretty much the whole dash and all that jazz, when it came time to remove the hazard light box fuse thingy(? sorry dont know what its called) it broke. He finished up put everything back and now the hazard lights and turn signals wont work (obviously). I guess my question is, can someone please tell me what the "hazard light box fuse thingy" is, where I can purchase a new one for him, and if that will even fix the problem. The car is a 2001 honda civic if that helps. Any advice, suggestions, or links will help, Thank you
pictures help, upload to photobucket or this site and link on thread so we can see what you are talking about, if you mean the actual switch for the hazard lights then I would not be surprised if the turn signals circuit passes through that which would result, if broken, in none of the turn signals working.
You can get one of those at any junkyard if there are any near you or you could order it online from any parts store or ebay. Also check the fuses for the turn signals since they could have blown. Careful when working with the electrical systems, it can leave you in a world of headaches if do not do everything properly!
I guess it'd be called the hazard light button-- typically a dealer-only part or you should be able to pull one from a junked car. Turn signals definitely won't work without it, the circuit for normal turn signal blinking also goes through it.
elperdido
13
04-06-2011 06:13 PM
Knightshade02
12-30-2010 06:53 AM
dlion77
01-23-2010 09:03 AM
