removing a d16z6/y8
Old 10-30-2007 | 05:21 PM
Civic Dx 349's Avatar
Member
Default removing a d16z6/y8
I am in the process of removing my y8 to replace it with a z6 cause I spun a rod bearing. Can someone link me to a site that has pics and instructions on how to remove the motor? Im sure its not to hard but something to get me on the right track on what to remove first, second, and so on. Ive never taken a motor out before so if someone has some info and a link with pics I would really appreciate the great help!
Thanks in advance,
Tim.
Old 10-31-2007 | 03:42 AM
Default RE: removing a d16z6/y8
Disconnect (AND LABEL!!!) all Sensors and hoses
Remove axles
remove anything that is going to make the job harder (I pulled off my intake and exhaust manifolds to give me more room
Hook up the chain, pull all the bolts out of the mounts, and yank that sumbitch
Old 10-31-2007 | 07:12 PM
Member
I've checked it over and looks like it will be easy to get into all the mounts except for the front, upper drivers side mount and may have to remove a few things to get some wrenches in there. If Im not swapping a tranny at the same time do I still have to remove the axles and tranny? I wanna convert the car Im building now to a 5-speed with the tranny thats with the z6 motor but what else has to be changed to get the 5speed to work orther than the manual tranny? Sorry for asking all these questions but I figured it would be easier keeping it all in one thread then have 50 threads with different questions haha.
Thanks for the reply Forty04!
Old 11-01-2007 | 03:00 AM
It's much easier to pull it all, and swap trannys with the motor out.
As for the auto to manual, you'll have to run a search. There are a few threads and possibly even a DIY on here
Old 11-01-2007 | 03:41 AM
i found a link to a small diy
https://www.hondacivicforum.com/m_29.../tm.htm#295187
aprice
09-09-2005 07:31 PM
ohbiskits
12-04-2004 09:04 PM
Super Mario
15
11-10-2004 11:55 AM
j2t
11-08-2004 11:09 AM
dalifts
09-11-2004 05:28 PM
Quick Reply: removing a d16z6/y8
