Red RTV on oil pan = leak?
Old 11-05-2010 | 11:06 AM
beagler's Avatar
Originally Posted by mk378
Oil can also leak from the distributor or VTEC solenoid and run all the way down the engine to appear to be an oil pan or seal leak. About all you can do is clean off all the oil and watch carefully for where it first appears.
When working on a steel oil pan it's important not to overtighten the bolts, which will dent the pan upward around the bolt holes and cause leaks. After removing the pan, check that it is not bent from the last guy overtightening the bolts. Sealant should not be necessary.
Do you mean distributor cap? If not, please explain more.
Old 11-05-2010 | 11:10 AM
TiggerDX's Avatar
Originally Posted by RonJ
Buy a gasket for the oil pan:
I am on my second new gasket. Felpro rubber gaskets.
Old 11-05-2010 | 11:14 AM
TiggerDX's Avatar
I believe he means the O ring where the distributor enters the block.
Old 11-05-2010 | 11:17 AM
When you remove the oil pan again, check whether the gasket is torn. If so, replace with an OEM gasket. Clean all mating surfaces, and then only apply sealant at the locations indicated in the FSM. Torque the nut and bolts exactly to spec in the sequence stated in the FSM in several passes.
Old 11-05-2010 | 11:24 AM
TiggerDX's Avatar
The gasket has only been on 2 days so I hope it isn't torn already.
The FSM states to apply liquid gasket on both sides at the corner of the curved edge, to the inner threads of the bolt holes and to the inner threads of the oil.
What are the inner threads of the oil?
Old 11-05-2010 | 11:25 AM
What car/engine do you have?
Old 11-05-2010 | 11:29 AM
The gasket gets torn when the nuts and bolts are over-torqued or torqued in the wrong sequence.
Sealant applied to the corner spots is sufficient.
Old 11-05-2010 | 11:44 AM
TiggerDX's Avatar
Thanks. I'll give it a shot and see what happens. Now have to go find a torque wrench that goes that low.
Old 11-08-2010 | 03:58 AM
beagler's Avatar
2000 Civic with a D16Y7
simons81
04-15-2014 03:16 PM
Koko4
09-20-2012 05:43 AM
Execut1ve
02-06-2012 07:29 AM
oilltd
06-10-2008 04:06 PM
Quick Reply: Red RTV on oil pan = leak?
