Rear Window Defogger not working.
I noticed this morning that my rear window defogger is not working. The light on the on/off switch has never worked (I bought the car used) but the defogger always worked.
A few weeks ago I had new rear speakers installed by a stereo shop. Today is the first time I have used the rear window defogger since then and it didn't work. Rear window stayed fogged up all the way to work.
Could the stereo store have disconnected a wire or something near the rear speakers. Is there a wire back there somewhere I should look at?
Any suggestions would be greatly appreciated.
Thanks,
Thanks,
RE: Rear Window Defogger not working.
There's also a relay in the engine bay fuse box. If you listen there while someone presses the defogger button (with the key on but engine not running) you should hear it click. If the fuse and relay seem OK, go back to the back glass and measure if voltage is reaching the terminals on the window. It is possible to cut all the printed wires at once attempting to clean the glass or scratching something across it.
ORIGINAL: mk378
OK, I went out during lunch and looked around my rear window. On both sides of the window there is a clip for a wire to connect to for defogger but only the drivers side has a wire connected. The wire is coming of from the plastic cover over the rear pillar. Should both clips have a wire connected?
By the way, it is a 97 EX Sedan, AT.
Thanks for the help.
Yes you need both wires connected. One is the power supply and one is ground. The wire clips should just push on, but don't use excessive force because they're glued to the glass.
Thanks for all the help!
I called the stereo store and they said to stop by and they'll hook it back up. I can't get there until the weekend so I'll probably give it a shot myself if I have time. Right now there is no wire showing at all so I think I'm going to have to remove the plastic pillar cover.
ORIGINAL: foress_89
Your windows are fogged at this period of the year?
I moved here from LA in 1999 and I don't care for the winters.
Hobo
01-06-2008 03:23 PM
stulp
07-07-2007 12:56 PM
