Rear quarter panel questions...
Old 11-30-2006 | 11:29 PM
classiccarsrule85's Avatar
Default Rear quarter panel questions...
I am looking into buying a CRX for cheap but anyways.....I am wondering how much rear quarter panels are for the car it is a HF model if that makes any difference??....it is the body style of 88-91 crx's dont know the exact year but yea...how hard would it be to repair and make it look correct since the job done was bassically bondo and bondo no good for me...
thank you
Old 12-01-2006 | 04:54 PM
burnindesirez02's Avatar
Default RE: Rear quarter panel questions...
well for my 93 Civic Ex my quarter panel costed around 500 dollars and then another 600 to put it on. the guy that did it did a good job and you can't realliy tell. Its on the driverside of my car and it looks stock. But it will cost you some money. I am not sure just saying the mine was quite a bit.
Old 12-01-2006 | 06:47 PM
if ya get the right tools and take your time it should look perfect with enough final prep!
ya need to bend a lip onto the old metal and tach weld the new steel over and over and over till the tach welds are complete.... but dont weld for to long cause heat will cause it to warp preaty bad.... and then you have ALOT more work on your hands then!
if ya dont want to do all that work just take it in and have it done...
but depending on the ammount of damage ya might just hammer it back out or slit some areas or section out the realy badly bent and weld it back together...
AJDux
05-01-2012 10:35 PM
BrutalXApollo
08-27-2009 04:58 AM
frocashmoney24
09-27-2007 09:06 AM
HONDUH LOVER
03-05-2005 08:37 PM
Quick Reply: Rear quarter panel questions...
