Rear endlinks making clunk sound going over bumps
Ok so I'm having this recurring problem of my rear end links making a clunk sound when going over bumps/rough road spots. They are Blox adjustable endlinks.
At first it was because I wasn't using the correct side spacer which kept the bottom end a tad loose on the bolt, even after tightening it as much as it could. Added spacer got rid of the noise and the ride felt/sounded perfect.
Now it's happening again, been going on for a couple weeks now. So I go under the car to see if I can move the links to replicate the sound and they feel secure, but I think the bearing inside the endlink housing is wearing out or creating a space so anytime there's no pressure it'll make a noise when it makes contact on a bump. Does that make sense?
So I'm thinking, I could lengthen the endlinks so there would always be a slight pressure on them so they wouldn't "clunk".
But a couple questions.
1. Would OEM rear Si endlinks work for skunk2 rear control arms(not sure if the bolt/thread size would match or are they all the same size)
2. Would blox or other brand none adjustable endlinks solve my problem?
If it makes any difference I drive in a dusty environment almost daily, I would assume that causes wear on the endlink bearings, but I didn't think it would destroy them that fast.
celestialwolven
02-26-2011 07:34 AM
elkydwodo
12-05-2007 12:03 PM
Lambo Civic
11-17-2007 09:17 AM
