Mechanical Problems & Technical ChatIf you've got a problem you just can't figure out, a noise you can't diagnose, or a check engine light that won't go away, ask about it here!
i just did a couple of months ago.
if it smokes, probably need valve guide oil seals;
and you will be able to test for bad valves (if you do it yourself).
pull the head, exh, and oil pan and you can pull the pistons out with the block in the car. i do it all the time. would be a good idea to re-bearing the rods as well.
