Rattling noise
Rattling noise
Hey guys. I'm kinda panicing right now because my car sounds horrible. Okay to start I have a Honda Civic dx 1993. It was low on oil and I drove it anyways cuz I'm and idiot. So anyways, it ONLY had ONE rattling noise when it was at high rpm, like 5 or so. But then I guess I burned too much oil, plus I have a minor leak, so I almost ran out. That's when it rattled really bad. So I put some oil in from a gas station that I was near. But the car still rattles and it sounds like its coming from the engine side of the car. And also it started rattling when I push the clutch in. Or when I take it out. So does anyone know what happened?
One possibility is a bad bearing in the alternator. Pull the alternator belt off to see if the noise goes away. If that doesn't work, the you may need to remove the crank pulley (difficult) to check the water pump.
lunasin92x
12-18-2006 06:43 PM
