Random, Occasional Misfire on Cylinder 3
Hi there. I have a 92 Civic DX, and had it fail a smog check in CA because readings showed it was running fuel rich. With the help of my cousin who's a mechanic, I checked the cylinders to see if they were fully firing, and it turns out the #3 (facing front of the hood) cylinder wasn't fully firing. It's been 2 years since I replaced the spark plugs, etc., so I replaced the plugs (just the #3 plug initially, for testing), wires, cap, and rotor, and while the engine sounds like it's running smoother, I still get an occasional misfire on the #3. I believe it's still firing though, as when I pull out the wire for the cylinder, the engine runs slightly more rough than before. Any thoughts? Thanks!
Jon
Jon
Sorry for the latent response. I've yet to take it in but will be doing so tomorrow. I still strongly suspect some sort of a misfire, since whenever I pull the wire to the spark plug from the 3rd cylinder, the engine runs slightly more roughly, but not much compared to doing the same for the other cylinders which almost kills the engine. If the 3rd cylinder is not causing much of a difference with the wire in, already, wouldn't that mean there's some sort of misfire, or something's blocking the fuel?
Also, not sure if this counts, but when I switched out the spark plugs, the #2 plug didn't seem to look that different from the others--basically just had a hard, white covering (carbon?), for all of them. Hadn't replaced it in 2 years, so maybe that makes sense. If the injector was leaking and/or running rich, wouldn't it be more black? Just a random thought. I still should try the pressure test and injector swap.
Well, switched fuel injectors, didn't do anything. I'm guessing now it has to be something funky in cylinder #2. Could get a compression test--but what does that have to do with the engine running too rich? In any case, I've yet to take it in for a retest, but will do so tomorrow, see what happens.
lcynck
01-16-2015 03:16 PM
jriehl08
11-18-2013 04:06 AM
Infinitrium
02-12-2010 01:53 AM
jeevan chodu
12-31-2006 03:43 PM
