Ran into a couple of problems
so im close to finishing the swap but have a few probs . first off the shift linkage its in place but the shifts wont go in , the shifter is hard as hell and it bearly moves , the tranny has no tranny fluid just in case,and second when i press the cluch it goes all the way without any effort do i need to bleed it?
RE: Ran into a couple of problems
well with the shifter be sure your shifter the bottom part that bolts to the shifter rod isnt tight... on mine i used a jam nut on it to hold it snug and so the nut wouldnt back off as well. so far works good.
and with the clutch i would bleed it anyways.. just like bleedingbrakes, very easy with a clear hose and new fluid and aline wrench....
T money
01-06-2008 10:32 AM
Obligatory
10-06-2007 08:02 PM
althius
08-14-2005 01:03 AM
