Radiator- which years work?
Old 05-18-2011 | 10:49 AM
Honeybadger's Avatar
Default Radiator- which years work?
I'm not a honda guy (excluding old motorcycles ) and my girlfriend's civic has a long, nasty crack in the radiator. So, replacey replacey. Good thing it's the size of a 9 volt battery.
I'm going to hit the pick and pull for a replacement. It's a 97, so I'm guessing the 96-2000 ones should obviously fit. I recall a friend's 92 having a radiator of the same size in the same place. Will the previous gen's radiator fit? It's the bone standard 1.6, non VTEC (if that matters)
thanks in advance!
Old 05-18-2011 | 10:55 AM
92-00 D series will be the same. Technically the 99-00 Civic SI's will work too, however, it will be a pain to fit the d series hoses onto the B series water necks on the radiator.
If she has an AT, make sure to get an AT radiator. If 5spd, then any rad will work.
Old 05-18-2011 | 11:11 AM
Excellent news. That adds another 10 or so cars to the lot at pick and pull.
It's an A/T, so I'll look for one with the transmission cooler lines. I've never replaced an a/t cooler, is there anything special I need to do in regards to removing the lines? Will I have to top up the tranny fluid, or drain it altogether?
Old 05-19-2011 | 05:37 PM
*update* wound up finding an automatic, previous-gen civic sitting in pristine condition at pick 'n pull. The radiator was an almost brand new, aftermarket one.
Pulled it out, everything matched. Though when I put the fan on, it didn't quite match at the bottom (it used a different screw at the bottom than what was stock)
So I just screwed it in at the top and zip-tied it to the bottom.
The guy at the cash register only charged me $15 "because that little thing is only half a radiator "
Though definitely clamping those hoses for the A/T line would have helped. Spilled a good bit of fluid.
All in all, new hoses, clamps, a gallon of antifreeze, and a basically new aftermarket radiator wound up costing $45.
Thanks for the tip cvcr99, that saved me a ton of trouble.
space_ace
07-12-2010 05:44 AM
krytosss
07-10-2008 03:56 AM
branx
03-24-2008 05:32 PM
importcivicus
03-15-2006 09:28 PM
lilol89crx
07-29-2004 07:56 PM
