Pully or Belt??
Pully or Belt??
HI i have 96 civic coupe dx 5 speed 1.6NVTEC and when i just get in my vehicle and drive it when its cold i hear a squealing noise i when i push on the gas i am not sure if this is my belt or a pully or my alternator what u think???
is there slop in your belts? check to see if its tight. if not tighten it and see if it goes away. if its cracked. buy a new one there cheap. if the problem remains check to see if your power steering pump is going. could be a number of things, water pump, oil pump, AC pump etc.
Yeah tighten those suckers as tight as you can...But not too tight if they're old..but if they're old they should be replaced already. To check the slack, turn the belt with your hand from side to side...it should not go beyond a 1/2 turn.
The alternator is the one that will squeal on startup. Normally the alternator draws a lot of power when first started, as it needs to recharge the battery. The power steering belt is most stressed when you turn the steering all the way to one side, and the air conditioner belt, naturally with the air conditioner on.
