Problem with Overdrive/Heater???
Old 01-02-2008 | 05:54 PM
brinriha's Avatar
Default Problem with Overdrive/Heater???
Ok its COLLLLLLDDDD in Illinois.
Well today I am cruising down I80 and the temp guage says a little before halfway on the guage. Now the car starts slipping in and out of overdrive. Now I remember somebody here saying overdrive is controlled by the temp of the engine. Is my temp too low or is this some other problem. Now the kicker so I am thinking well if I turn off the heater will it go back into overdrive. Well I started sliding the lever on and off and overdrive was in and out. So what can be the problem. Any help would be very appreciative. Thanks,
Old 01-02-2008 | 08:11 PM
Default RE: Problem with Overdrive/Heater???
warm car up and while car is runing check transmission fluid. if u want to get heat put a piece of cardboard in front of the radiator to block cold air. this works great.
Old 01-02-2008 | 08:30 PM
Is the Check Engine Light (CEL) ON? If so, you might want to determine whether code 19 is stored in the ECU (A problem in the Lock-up Control Solenoid Valve A or B circuit). The procedure for retrieving a CEL code is described here:
http://www.honda-tech.com/zerothread/1901557
Old 01-03-2008 | 01:28 PM
brinriha's Avatar
No I have heat. But when I switch the heater from on and off the overdrive slips out and then back in. I have heat for the most part.
No codes, No CEL
Thanks
tmont2
12-07-2009 03:08 AM
Jimbo&2000SI
04-22-2009 12:04 PM
FocusBoy949
07-30-2006 02:55 PM
AgentofDarkness
07-06-2005 03:51 PM
spevie
05-27-2005 08:34 AM
Quick Reply: Problem with Overdrive/Heater???
