problem with d16y8 head
Old 03-12-2013 | 09:38 AM
gera56's Avatar
Default problem with d16y8 head
i have a '91 civic hb recently the d15b7 that had on it blow up,i bought a d16y7 with a d16y8 head on it,the block had a thread on one head bolt damaged,i fix it put a new head gasket,set the head,torque it down,and when i started it it's leaking oil between the head and the block on the timing belt side,any help will be greatly appreciated.
Old 03-12-2013 | 09:50 AM
Did you torque the bolts down in the proper order and in intervals? If not, you may have ruined the gasket.
Torque Sequence:
9 3 1 5 7
8 6 2 4 10
(front of car)
In 4 steps:
1. 14 lb-ft
2. 36 lb-ft
3. 49 lb-ft
4. 49 lb-ft (bolts 1-2 only this time)
Old 03-12-2013 | 06:25 PM
gera56's Avatar
yes i did,i'm thinking probably the block is warp,which it will be very rare but not impossible
Old 03-12-2013 | 07:48 PM
gera56's Avatar
i did,probably the block is warped,the head i know it has been refurbish,
rebrak24
09-15-2005 11:54 AM
BoomBox
ED-EF Swaps
06-23-2005 09:48 AM
BoomBox
06-06-2005 04:45 PM
fast93civic
01-15-2005 03:16 AM
94si
EG Swaps
12-14-2004 07:53 AM
