power window quick question
#21
RE: power window quick question
ok so if i wanted to use fuse five where would i splice another wire to it. do i go behind the fuse box and find the white/yellow wire or what do you recommend. b/c it is a bitch to locate where that open is b/c my relay is working and my #5 fuse is also good.
#22
ORIGINAL: import4life
How do you plan to make the connection of the other end of the new wire at the window switch?
#24
i would probably splice it to the wht/yellow wire as close to the switch as possible that way i wouldnt be pulling the wire out of the connector
As addiction mentioned, what's your plan on routing the wire from under the dash into the driver's door?
#26
I finally got my driver side window working with the master driver switch but now i realized that withthat master switch i can't operate the passenger side. Do i have to jump any wires on the connector to operate the passenger side?
#28
sorry for taking so long but i finally had time to work on my car.
ok so this is what i found as far as the passenger window goes.
I have power going to the switch and i can here the motor trying to work but like somthing is not letting it. but i did notice this, on the five pin connector everytime i put my test light to the blue/grn, blue/wht, blue/yellow, and blue/red and i hit the switch i can hear the motor trying to work. what does this mean?
#30
As you are hearing the motor attempting to move the passenger window, you may have a bad window regulator.
Here are some more electrical tests. Perform the last test (4) on the connector attached to the driver switch.
