power window problem, any help please!
2002 Lx 2 door coupe, passenger window goes down but NOT UP when using passenger door switch. When using driver door switch, passenger window does NOTHING.
I replaced the power window regulator and passenger door switch. I can get the window to go up and down by passing switches , wiring directly from battery to power window regulator.
Any suggestions appreciated!!!
Could be a bad switch in the driver's door, or broken wires between the door and the frame (which almost always happens on the driver's side since that door is opened and closed a lot more). The circuit always goes through both doors and both switches.
tbux22
03-13-2012 10:18 AM
eisenberg
02-14-2010 07:14 PM
AGibney
12-29-2009 05:59 PM
