Power window problem
Old 01-02-2008 | 04:29 AM
wileec's Avatar
Default RE: Power window problem
Thanks Ron, still working on this. Just had a thought I have had an issue in the past off and on when I get out of the car I sometimes get a small shock when I brush against the door, could this be related or ita different common problem.
Old 01-02-2008 | 07:50 AM
ORIGINAL: wileec
Thanks Ron, still working on this. Just had a thought I have had an issue in the past off and on when I get out of the car I sometimes get a small shock when I brush against the door, could this be related or it a different common problem.
It's possible, though the shock might also come from simple build up of static charge.
Old 01-02-2008 | 08:01 AM
wileec's Avatar
ORIGINAL: RonJ
Thanks that is what Iwas thinking but thought I would check. Going out in a bit for more fuses if they do not blow I will stop at the Honda shop and pay out the but for a new switch. 87 in stock new on line was 65 + shipping and time.
Old 01-02-2008 | 08:14 AM
Mylittlecivic's Avatar
i had a problem like this where i lubed my windows up and they worked fine and then........... my driver side window just died then started clicking so i tried to roll it down and the auto came on forcing my window down where it stripped all the teeth on the window regulator.
hope you have better luck
Old 01-02-2008 | 08:21 AM
ORIGINAL: wileec
Just a thought. It appears that the passenger switch component alone is bad due to a short. Maybe you could simply replace the one bad switch? However, I don't know whether the main driver switch assembly can be taken apart. It might be worth looking into.
Old 01-02-2008 | 10:52 AM
wileec's Avatar
I started to pull it apart but the control box is held together real tight.
I did find a used one localy for $50 not sure how reliable this kind of part would be. Might be worth spending the money on new?
Old 01-02-2008 | 10:56 AM
ORIGINAL: wileec
Ask whether the seller will allow you to run the continuity tests on the used driver switch assembly. If it checks out okay, then it is likely fine.
Old 01-02-2008 | 11:00 AM
wileec's Avatar
I know I would have at least 30 days and I would be able to plug it in right away to make sure it worked. I am just worried about the wear on a 7 year old part that is mechanical and electrical. After all I wore one out already.
Old 01-02-2008 | 11:18 AM
ORIGINAL: wileec
Yeah, that's a personal call. What's the cost different between new and used?
Old 01-02-2008 | 11:27 AM
wileec's Avatar
about $35 50 used 87 new.
Quick Reply: Power window problem
