power window not working
I need some help I have a 95 ex coupe the passenger window quit working.I got a new motor for it but that didn't work so what else can it be (relay,switch). If it's a relay dose the drivers side have a different relay because it still works.
Could it be the master switch has went bad?????
I called the honda dealer and the guy told me that if the master switch went bad that the other switch (passenger side) would not workis that true???
Maybe a bad wire? any help would be great thanks!
RE: power window not working
The relay is fine. It is most likely a blown fuse, the driver's switch, or passenger's switch:
1) Check whether fuse #8 in the under-dash fuse/relay box is blown.
2) Remove driver's door panel and power window switch assembly. Use a continuity tester to perform the Driver's Switch Assembly Test (see picture 1)
3) Remove passenger's door panel and power window switch assembly. Use a continuity tester to perform the Passenger's Switch Test (see picture 2).
Replace any bad component. If applicable, you might be able to save some money by purchasing a used switch assembly from a salvage yard.
*Thanks goes to Danomatic93 for tips on picture uploading*
Ditto on the fuse!! Always check the fuses first. I drove around with 1 headlight out for a month and thought my wiring went nuts. All because I forgot to check the fuse!!!
thanks but I went out yesterday and my ac/heat controls and my defrost is not workink also I don't have a fuse diagram but I pulled all the fuses in the box and they were all good
For clarification, are you saying that the A/C and heater blower controls don't work? When you say defroster, is this also a blower problem or something different?
If the blower simply doesn't work, then you can troubleshoot the problem as described in the pictures. [Picture order = 21-12, 21-13, 21-14]
cobr888
11-13-2014 12:14 PM
eisenberg
02-14-2010 07:14 PM
chrisroug
10-02-2006 11:36 AM
Kturner
09-25-2006 08:38 AM
