Power Steering Pump Rebuild Gone Wrong... help needed
Hey guys, I purchased a new bearing and seals for my power steering pump. I rebuilt it using the Honda service manual, and I did everything right that I know of. I bled the system and added fluid like I was suppose to.
Well now, when I turn the steering wheel, the whole car shakes, and it sounds like the steering rack is grinding.
Any ideas?
Any ideas?
I had my friend turn the wheels (while jacked up) and watched the pulley and the belt did not appear to be slipping.
I bled the system, but maybe not enough? I turned the wheel lock-to-lock for about 5 mintues, with the front end jacked up.
Would this happen if there was too much fluid in the reservoir? I accidentally put a little too much in, but didn't think it would be a problem. It's a little above the max line.
alright
i'm about to take the pump off and apart again
also, upon further inspection it seems that the noise comes from the pump, however, i can feel it in the steering wheel and it shakes the whole car.
also, while the car is jacked up it doesn't shake and grind as bad.
