power door locks not working right
Old 08-12-2009 | 01:55 PM
xpdude's Avatar
Default power door locks not working right
when you hit the lock button or turn the key in the driver door you hear the car cime, shouldn't all the doors lock?? they don't, the driver and pas side don't lock but the rear do. also the window comes off track unless i hold it going up. any ideas?
Old 08-15-2009 | 04:27 AM
bmelloh's Avatar
On the 96 and up get the window back in the track and spray silcone bout 1 time a month in the track front and rear to keep it in track, this is what Ive bee doing and no more problems, as far as the locks, mine lock from the inside , but have to use the key to lock from the outside, havent had time to resolve that issue
Old 08-15-2009 | 07:29 AM
What year?
Old 08-16-2009 | 09:55 AM
xpdude's Avatar
Default pwr locks
its a 97 civic lx sedan. i hit the lock button on the inside and the rear doors lock, the front do not. i have to manualy push them down. plus the drivers window comes off track while rolling up. i mave to force it against the rear with my hand to roll up properly. when you say spray silicone, won't that freeze the window shut or in place? when you say front and rear track, thats the part where the glass slides up and down in?
Old 08-16-2009 | 09:59 AM
Do you have a model that supports a keyless remote? Sounds like the front lock actuators are bad. Just make sure they get battery voltage when you push the switch.
Old 08-16-2009 | 10:53 AM
xpdude's Avatar
Default pwr locks
i do not have the keyless entry. wish i did though. lock actuaters? is that like a motor?
Old 08-16-2009 | 11:02 AM
The actuator is the solenoid that moves the locks. Below shows how to test.
Maybe you just need a keyless remote. Does the stock radio have two plugs in the rear? Do you see a valet button in the front of the radio?
Old 08-16-2009 | 03:09 PM
xpdude's Avatar
Talking door locks
I don't see a valet thing or a bulb for a remote to bounce off of. where is the diagram that shows how to test it? so how does the door panel come off without destroying it?
Old 08-16-2009 | 03:20 PM
Old 08-16-2009 | 03:46 PM
You don't have keyless if there is no valet switch in the radio.
billy75
06-19-2013 11:17 AM
fbbyrd
08-12-2008 05:16 PM
Güero
06-24-2008 08:58 PM
Kturner
09-25-2006 08:38 AM
cjafoster
09-06-2005 11:38 PM
Quick Reply: power door locks not working right
