Power Door Lock Problem
I have an issue with my power door locks. If I cycle them 2-3 times, they are usually fine. But after that they start to not lock/unlock certain doors then they just stop all together. Is this a common problem? Possibly the Power Door Lock Control Module? Any help would be appreciated.
RE: Power Door Lock Problem
How old is the car? I assume its a sedan. If it's over five years old check for moisture in the doors...sometimes when in warm and humid climats actulators have a hard time working right.
It is a '97 EX. Where exactly should I be looking for the moisture? They act like they are running off of a battery and it is draining down every time you actuate. If you wait a couple minutes, it works normally a couple times.
redraif
03-07-2013 01:59 PM
Koala
10-12-2007 09:38 PM
