PLEASE HELP!!!
PLEASE HELP!!!
I have a 96 ex and my cooling fan is not working, i tested power at the fuse and i have power, but no fan, what could the problem be, o and i checked the relay too, there is power there as well, someone help with this as warmer weather is coming i dont want to have to worry about an overheating car. i also dont have a temp guage cause the previous owner broke the needle clear off, so if anyone has a stock guage cluster and wants to take out the temp guage that would be much appreciated!
thanks for any help with this!
RE: PLEASE HELP!!!
Find the thermal switch it is on the thermostat housing which is at the engine end of the lower radiator hose, near the starter. Disconnect the switch and jumper the two pins in the plug leading to the car. With the jumper in place, the fan should run whenever the key is on. If it does the switch must be bad. If it doesn't, leave the jumper in and the key on and see if voltage is reaching the fan motor plug. If you have 12 volts there but the fan does not run, the motor must be bad. Those are the two most common problems.
RE: PLEASE HELP!!!
ORIGINAL: mk378
With the jumper in place, the fan should run whenever the key is on. If it doesn't, leave the jumper in and the key on and see if voltage is reaching the fan motor plug. If you have 12 volts there but the fan does not run, the motor must be bad.
RE: PLEASE HELP!!!
ok, so heres the deal, i put a jumper in the and it worked!!! thanks for the help and the definite fix to my problem!!! now im just going to leave the jumper in till i can get a new thermal switch, is this something that i can get at any parts store, or should i just get it from the junkyard?
DontHateOnEG8
20
09-06-2008 06:49 AM
